Ok getting close to attempting to start my 468 swap in my 74. I added a few accessories under the hood. I have a electric choke, kickdown swith for th400, dual spal electric fans plus hei distributor. Now from my understanding is that i need all of these to be triggered by a 12+ volt with the key on. I was hoping to run a distribution/junction box so i could fuse every line and minimize the wires going thru the firewall.. is there a better way.
If you can find your switched wire under the hood, I would definitely look into using a relay on the distribution block, then wiring it right to the battery. You don't want to overload the 45 year old wiring.
Ive been stuck on that one for a while. Cant seen ti figure whick color wire that should be . I have to do more reading
