I bought new radiator support bushings from the paddock. When installing the fenders the gap at the door is way off seems as the bushings are to thick even after torquing. If I remove the bushing the gap is even. Has anyone had this problem? Any ideas appreciated. Thanks
check your body bushing and the subframe where they attach, if the frame is rusted out at these points or the body mounts are bad it may do that. my 74didn't have spacers at the firewall,the bushings were .4" thicker so if you replace them, compare them to the old ones . you may need to get spacers ,or have to make them.
