Hey guys,
I need new outer seals for the windows on my 73 nova. i need these for both front and rear. What are my options for keeping the rear window still functioning? my rear windows work without issue, just need to replace the cracked rubber on the outside of the front windows, and need new front felt, and then outer rubber on the rear window, and want the rear window to still roll up and down.
If you could pelase adviase a kit that would do all the windows, im not sure if what these are actually called, i assume they are called window seals, but not sure.
Discussion Starter #2
also what is the correct name for the part that goes in the top of the window and down the back, I figured out that the part at the bottom is called window felt trim.
I looked at my rear quarters, looks like I need the bottom outer and top seals on both, my front felts are good.
On my doors I need inner and outer on the bottom, and the seal that goes around the top, and down the back
Sent from my Pixel 3 XL using Tapatalk
I have a 74 and my understand is that there isn't a replacement for the rear windows that will keep them functional. The replacements make the window stationary. I'm not to the point in my build yet to have to figure something out, but I wonder if the "stationary" kit could be combined with some oem parts to make the window roll up and down..
I actually never roll the rears down. I always hate how they look broken when rolled down. I really wish GM made them go all the way down like other cars.
Yea that is pretty lame. There is plenty of room for them to roll all the way down.
I really only have to have to bottom outer felt. The top channel on mine seems to be ok just the chrome piece is rusted. And the felt pieces on the front are in good shape
