First Things First
Hello,
Welcome to the site and thank you for your service to this country. First check for the hidden VINs and here is the URL to help find them http://www.stevesnovasite.com/forums/showthread.php?t=131922. Next check tire pressure of each tire, if one side is over-filled and the other is under-filled you may also have a bent frame. After that look to see if your nova's body has been partly welded into a sedan from a hatchback. In the worst case scenario the VINs do not match check if the other VIN was stolen if the other VIN is not stolen then you should be able to keep the nova without calling the cops (maybe the other nova was a donor car or something). Hope this help you out.
Hello,
