Having an issue with my 73.….I have not ben driving it much as I was working on it. but it seems to have always had this issue , in the back of my mind, but it seemed minor and sporadic. I fired her up and went for a ride and at WOT she would cut out, the tach( autometer) would freeze at various readings , like 4k. then she would come back to life, usually after, but not always, I let off the gas. SO it seems the HEI is loosing power, vice a fuel issue. My friend was with me and he said he got shocked getting out of the car...
I think I must have an intermittent ground in the + to the HEI circuit.
New HEI distributer, wires plugs etc. clean fuel and filter.
Yesterday I replaced the tach and + wire crimp on connections ( spade/ blade ) and added a Accel snap in connector ( PN 170072), thinking a vibration was loosening the + terminal at the Cap connection. Fired it up and connected my timing light. once warm the engine idled a bit rough, like it had a moderate cam , which it does not. and my eyes were burning some , although no smoke was visible from the exhaust. I attributed it to the PS header, which I painted with OER exhaust header paint and its burning off. DS I painted with rust oleum BBQ black and its fine. Now I think it was unburned fuel and the paint.....
Back to this issue. The timing light would fire correctly 4-5 times then skip...a beat. repeat. Next the idle smoothed out and went up to 1,000. I turned it down to 750 and base timing no vacuum was 10-12. about this time I realize that I have been adjusting the idle up and down frequently over the last few years.
I tried to check the timing at 4k and got around 34-36 initially. However when done I had 40 at idle. No idea whats up with that… borrowing my friends lite to check again tonight. Yes I checked 5 times and I'm on #1 plug wire. I shut her down and checked the cap rotor and weights , all good.
Then I started checking the + wire. For some reason it was routed towards the starter side vice the firewall.... eventually I found it doubled back and went in the firewall. all wires are wrapped in looms. I didn't find any problem yet with the wire, however in cleaning it the words "resistance wire do not cut" are visible. that explains why it was left so long.
I looked at my wiring diagram and :
The 6 and 8 cylinders came with different resistance wires, 1.35 ohms for the 8 and 1.80 ohms for the 6.
My car originally had a 6. now a 350.
Given my car was switched to HEI before I got it, does the resistance of the wire have any effect on the HEI?
IM thinking that the resistance wire was probably for condenser noise suppression?
SO I'm following the wire back to the ignition switch hopefully tonight. I intend to use my multimeter on ohms beep to see if the + wire is grounding as I move wires around. With key off yes .
I cant tell in my diagram: is there any of the ignition circuit up in the steering column or is it all in the plunger switch and the long flat connector under the column?
where is the ignition switch located?
Is the firewall plug and actual plug connection or just a sealed pass threw?
I order to access the plug from the inside does the fuse block need to be removed?
on the engine compartment of the plug the + wire is black with pink writing, and is resistance wire. Inside the firewall it should be a pink wire from the ignition keyed on switch.
Thanks for reading and for any replies.
