hi i need to get the drivers kick panel out of my 73 i removed the screws around the vent . tyred to pull it out but the vent is still in the hole on the side of the firewall it hits the e brake handle assemblie do i have to remove the ebrake
do i have to undo the cable on the ebrake as well as the two bolts on the firewall if i undo the bolts on the firewall can i pull the ebrake out with out undoing the cable
you don't need to remove the entire e-brake, just loosen it and slide it over about 2 inches give r take. then lift the panel and wiggle it just a little bit, haha. good luck.
i removed the fuse panel on my 69 and the park brake. not sure if u have to remove the fuse panel, but it sure made it alot easier.
