1 - 2 of 2 Posts
Need a lil help here...
I am looking at lowering my stock 72 Nova (original power steering) column.. with one of the IDIDIT brackets... Before I rip the bracketry off the floor board I thought I should ask first. Will the stock column drop 2"s without any problems? Do I just notch out the floor a bit to allow the column to drop.. and then bolt it back up under the dash with the new 2" drop bracket?? Never done this.. wanna go about it the proper way. I see this column as a 2" in size.. correct?? Thanks for the input. :D
Discussion Starter #2
I guess the question should be... Can you drop a stock steering column 2" without causing a bind anywhere?? Pointers please?? on dropping a stock 72 Nova column??? Thanks!
1 - 2 of 2 Posts
