1 - 18 of 18 Posts
I seem to be missing some brackets. does anyone have a pic of a setup like mine? Can't find anything online.
the PS is missing something and the a/c doest line up.
There is also a bracket shown i have no idea where it goes.
Thanks!
402515
402516
402517
402518
Vendor
The assembly manual and factory service manual will have pics, diagrams and information on the A/C. I strongly recommend picking them up for guidance with the A/C system. eBay usually has the best deals. Faxon makes quality reprints.
The A/C take 5 brackets I believe. What I see generally looks correct. I don't see the big rear adjuster bracket that comes off the intake manifold over the valve cover. There is also a small rear pivot bracket that mounts to the exhaust manifold. Do you have that one?
The bracket in your hand sort of looks like the rear power steering pump bracket that mounts to the block and motor mount.
thanks,
these are the only brackets I have, this was pretty stripped down when I got it.
ill get that manual and hopefully locate some parts.
thx
ordered the nova assembly manual, but only God knows when it will arrive.
i did find another bracket that mound to the intake. Something is wrong though, nothing lines up.
I also found this bracket which I have no idea where it goes.
402581
402582
402583
402584
anyone have a pic of there power steering and a/c bracket setup. I'm a visual learner :)
Vendor
The A/C compressor is sitting too far forward. You may have it mounted to the front of something when it should be the rear. Otherwise it looks like you have all the brackets.
Vendor
Discussion Starter #12
it looks like the only part im missing for the PS is this one circled in the pic.
does anyone have one to sell me?
thx
402645
Vendor
That is likely the bracket you have in your hand in the pic. It very well could have been different on A/C cars. Brackets often changed with all the various bolt on accessories.
Discussion Starter #14
ive tried to see where it could possibly mount but there is no holes that come close, dont you just love when people take things apart, then you have to figure it out? I have boxes of crap that i have no way to identify. I hope when i get the assembly manual it shows some of them.
Now when I take stuff apart, I bag and label everything. Even then, I lose stuff and can't figure how to put it back together! My Dad had a bunch of metal tags with thin bailing wire stamped with numbers from 1 to 50. He would take stuff apart and make notes and drawings on a piece of cardboard, and tag each piece he took off. He was a helicopter pilot in the Army and I guess that's where he picked it up. There was no internet to save you then!
Discussion Starter #16
it turns out that bracket i had a pic of was the one for the pump. here are pics in case someone else ends up with a car that's apart.
402733
402734
402735
402736
402737
newstang . .. . . you may can 'check' some - or - all your "brackets" when you get your FAM . GM did stamp a lot of those 'hard-brackets' with the part numbers. (like the brackets in Post # 12) … I did buy some "power steering brackets , for my " 250ci six motor" and almost all of those brackets DO have GM part numbers stamped on them. So, I looked & my FAM has those numbers . Worth checking . and, I have found that a lot of GM (maybe not aftermarket) ,
pulleys have numbers on them. (just a lot of time - - nobody looks).
# 1 - - 250 water pump pulleys =
# 2 - - or stock GM "Fan Blades" with "part # & build dates " : one , 68 - 7 blade : one, 69 - 7 blade .
. . . 1969
# 3 - - . . . 1968
That "water pump pulley" - - I've been looking for another one - - for 20 years, now.
That "A/C Fan Clutch" . . . been looking for another one , since 1996 . Has the x-tra 'step to the w/p .
never hurts too 'write those numbers down . . . … jim
thanks,
thx
These are pics from my 72 factory AC car up the hill B
1 - 18 of 18 Posts
