1 - 11 of 11 Posts
I have a 72 nova want to change from manual to power sterring the new unit is off a nother 72 can i use every thing from that like rag joint, gear box, pump, brackets,arm, and hoses.Thanks tom
Yes you can as long. Only the brackets need to be off a small block which I assume they are and you are putting them on your small block. Good luck.:yes:
^^X2, everything should bolt right up from the rag joint down, you'll need the pitman arm from the power steering box too.:yes:
Do you think there is any problems with me running full length headers.
Usually SB don't have too much of an issue with headers, unless you have large tube headers. I would like you'll be safe.
I had to clearance my 1 5/8" primary headers for my power steering. Not much but it needed to be done.
Running Dynatech 1 3/4" x 1 7/8" headers and no problems with the power steering box or spark plugs either. Pittman arm was touching the header tube at full left turn.
1 - 11 of 11 Posts
