I have a question for you experts. I have a 72 which had the aluminum trim around the door window frame and quarter windows. When I bought the car it only had the quarter window left trim on it. There is no trim on the door frames now so when I use the painted trim for the quarter windows, do I need something on the door? Probably asking the question wrong.
Quarter trim
If you are using the outer quarter glass trim that is painted body color there is normally no door trim. if I understand your question correctly.
Just to add, if your car has the aluminum on the quarter windows they are not an 'overlay' like the door frames. What this means is that you will either need to add the aluminum overlays to the doors, or remove the aluminum moldings from the quarter windows and replace them with painted ones.
BTW, the repro aluminum set from Corvex is excellent....
I just went through replacing all the aluminum trim on the door frames and 1/4 windows on a 70 2dr. It takes a little finesse to install, but it's a good fitting repro trim (Corvex). I ordered the set through Chevy II parts.
Agree, I got mine from Joe Grom at Chevy II Only as well - he's a good guy!
FYI - I have a set (both left & right door) top trim pieces that I didn't need. Did I mention you have to install them with some finesse... I bought a 2nd set. If any one is interested, let me know.
