Here we are on 1.1.2013 for the year's first installment of Expensive Mistakes and How not to Build a Car :willy: .
So back in early December my Autorad showed up. I must say they are very nice pieces and well worth the wait for a quality fabricated component. Around the same time my V/A Frontrunner came in that I picked up from Matts during the Black Friday sale. Anyway, now that the holidays are over I made some time to try and fit it up. Radiator/fan and accessory drive fit is something I've been worrying about since summer. There just isn't much clearance on the Novas between the big block and core support. I needed all the space I could get for this setup and hoped that the Autorad would yield what I needed. This was basically my only bolt-on type option available.
Long story short, it isn't going to work. I have 6.5" from block face to the back of the fan motors and I need closer to 7" for the Frontrunner. As luck would have it the passenger's side fan motor is basically right in line with where the A/C compressor is positioned. That also happens to be the longest dimension with the Frontrunner. It looks like I only netted about .5" extra clearance with the Autorad setup.
I guess now I have to think this over and decide where to go from here. I think I have basically 2 options. Well 3 if you count pushing the whole project off in the river :wow: .
-Option 1 is to scrap the big block plan and go LSx. I'd have to sell off some parts and likely take a bath on those. I haven't opened the Frontrunner so maybe I could exchange it. This radiator is single pass which also presents a little problem for the LSx option.
-Option 2 is to build custom frame stands that move the engine back .5". There is plenty of header and firewall clearance to do that. It actually would help gain clearance for the headers around the steering box. This would require not only custom frame stands but also a custom trans crossmember. Another potential benefit with this is it just might get the header tube far back enough to also clear a Ridetech Tru-turn setup.
This big block is fighting me all the way it seems...
Here is a shot showing how much an Autorad gains you in radiator surface area. HUGE difference in opening size versus the OE style "heavy duty" core support.
Here it is with the radiator installed. The condenser mounts directly to the radiator.
Here you can see better what I mentioned earlier in the thread about the Autorad radiator mounting surface not being so far back. The tape line is pulled between the center line of the rear most fender mounting locations on both the OE and Autorad support. You can see the Autorad radiator mounts .5" forward of the OE setup.
