big PITA ... for sure .
even, the bolt-on door hinge ... but, somewhat better, 'cause you can remove each / or both hinges to replace the p & b's.
But, that makes you re-align each door / fender.
Tip : with "bolt-on-hinges" ... make ( TWO ) aligning bolts -- by matching your door-bolts : cutting the 'Heads off' and insert one bolt at the top -- and one bolt in the bottom position (bottom hinge) for "guide-pins" -- JUST - HAND - TIGHT -
Then 'rest the door on your legs / knees' and push guide pins & door towards the top hinge .............. get the 'picture' .................
makes installing the 'door-hinge-mounting-bolts' ALOT Easier into that "Floating Plate".
I have done that several times by my self -- and, was not that easy , even when I was alot younger .. mostly before I 'Painted anything'
............. (I know -- not on welded door hinges) .
