I'm putting a different v8 engine in my 63' soon and I want to change the 2 speed powerglide transmission while I'm at it.
It will be a weekend cruiser that will see about 50% highway time so I'm going with an overdrive transmission. Either the 700r4, 2004r, or 4l60.
There's a shop close to me that has an early 90's rebuilt 700r4 ready to go for $1250. 12 month warranty.
I know that if I go with the 700r4 that I'll have to shorten the driveshaft and probably modify/replace the mount. Those shouldn't be a problem.
I've never dealt with rebuilt transmissions before so I thought I would ask what you guys thought of what they say has been done to it.
Is the following list pretty much what you want to see in a rebuild?
Anything missing that I should know about or ask the shop about?
700r4
Hi-temp 4l65_4 clutches 7 stack up
All new:
Band
Filter
clutches
Seals & gaskets
Bushings
Accumulator pistons
Trans go vb plate
Sonnax sun shell, boot valve & reverse boost valve
Pump veins and hardened rings
Up-graded sprags (springs?)
New 1800-2100 converter
Constant line pressure mod done which changes the tv line to only working the shift points instead of regulating the pressure.
Apparently this mod isn't the TCI Constant Pressure Valve Bodies mod but something else entirely.
Any ideas?
700r4
All new:
Band
Filter
clutches
Seals & gaskets
Bushings
Accumulator pistons
Trans go vb plate
Any ideas?
