1 - 2 of 2 Posts
i just put new air shocks on my 70 and noticed the driver side shock tops out at 30lbs of pressure. the passenger side seems fine. i took them off and both shocks are the same length. the only thing i notice is the angle on the driver side is sharper and the passenger side is allmost straight up. passenger side is in front of axle and driver is behind axle. any way to fix this? has anybody else had this problem? thanks for any info:confused:
69 and later Novas used staggered shocks. The locations are correct. They can be moved inboard if you fabricate or purchase inboard shock mounts.
1 - 2 of 2 Posts
