PLEASE HELP ME WITH YOUR NOVA KNOWLEDGE!!!! I was wondering if any one can help me? I have a 1970 nova and it needs a new sub frame I found one in excellent cond but its a 1974 will this fit my 70?they are both 2 dr cars and from what I can tell they look very similar. please help? any information you can give me would be greatly appreciated.thanks!!!
I think the main differences are the holes where the radiator support bolts on. I'm pretty sure they are the same for the most part. I know my aftermarket subframe says its for a 68-74. Here's a link that helps with differences between 68-69 and 70-72. Hope it helps. http://www.stevesnovasite.com/forums/showthread.php?t=114909
1974 Nova, 1977 Nova
Yes, it will fit.
Hi 70novadude,
Yes, it will fit but there are a couple minor differences.
The 74 subframe has different mounting holes for the front bumper than the 68-73 subframes. Easy enough to re-drill using your old subframe and/or bumper brackets as templates.
The 73/74 subframes are setup for the newer "clamshell" style engine mounts. That basically amounts to a couple extra brackets welded to the back edge of the engine crossmember. I don't think they'll interfere with anything but you could cut them off if necessary. Or make use of the 73-up clamshell mounts ... the rubber cushion is totally enclosed in a steel case so they won't pull apart like the older stock mounts could.
Hi 70novadude,
hi, have any pics? thanks
