Can you guys help with the correct water pump and crank pulley GM part numbers. I seem to be getting a different number from the assembly manual vs the GM part book.
70 Nova 396/375 HP no AC with P/S.
The water pump pulley is a single groove with a long pump and the correct part number should be???
The crankshaft pulley is a double groove and the correct part number should be???
Your help is appreciated.
Mike
Mike
