I have a 70 nova that was originally a 4 wheel drum car. I'm adding the factory 11" booster & front discs and keeping the rear drums. I need to verify which is the correct disc/drum master cyl for a '70. Some of the 'factory' style kits out there include the '69 MC listed below for a '70.
FYI: The factory Hold off valves are different from '69 to '70 - both castings and pressures. I don't know if there's differences in the MCs.
Listed as '69 nova/camaro : https://www.napaonline.com/en/p/NMBP1974BLV
Listed as '70 nova :
https://www.napaonline.com/en/p/NMBP2032
Ports and bore specs are the same for both MCs above: 1-1/8" bore. Besides the physical castings, is there any other differences between the two?
