The horn blows when I run it to the battery. But I'm beating my head against the steering wheel trying to figure out how this wire gets connected in the tower cam, on a 71, I know it locks in with a twist. Is this one something different as far as connecting it to the cam? I asked this before but could have been bad timing. Thanks
Here's a shot of the horn wire for my 1974 Nova but it doesn't look like yours though. Mine goes into a tube and by lining up the tab off of the side to a slot in the tube it is pushed inward to compress the spring and then when bottomed out given a little twist one way to lock the tab into the tube. I have had some that the spring did not have enough tension on it and by slightly stretching the spring it held it in tighter.
Thanks....yep, that's looks like the same operation as the 71', but I still have not figured out the one I posted.
