car was running crappy the other day when i got it back from trans shop,number 7 plug was badley fouled...has spark and good compression any ideeas?? thanks
Does it run good with the plug replaced by a new one? If so, bad valve guide or valve stem seal causing it to foul maybe?
Discussion Starter · #5 ·
the motor has been running pretty good as of late so i don't know why the plug is fouling,was running fine when i left it at the shop on friday when i picked it up it ran like crap so i who knows,i'll put some new plugs in it and go from there
Make sure #5 and #7 plug wires are on the right plug. They are next to each other in the firing order and next to each other on the engine. Real easy to get them wrong.
