1 - 3 of 3 Posts
I need a little guidance. The passenger side TS works fine. The driver's side works ok when the headlights are off, but stops working when I turn on the lights.
What could be the reason? Any help much appreciated. :yes:
What happens with the brake lights? I'm thinking a bulb may be in backwards. It's hard to do but can be done. Or there could be dirt & crap in one of the sockets that is causing a cross feed. The next thing would be to get a good test light and figure our where the back feed is coming from. There's no normal way for power to cross like that. The light blue and dark blue wires are for the turn signals when you are testing at the connector on the bottom of the steering column. Also, see what happens with your 4 way flashers on to see if there is a difference.
1 - 3 of 3 Posts
