Thanks for the kind comments. BHartje, I'll try to remember to put a tape measure to my intake this evening.
I took my Nova to Holley's LS Fest in Bowling Green, KY earlier this month. This was the first time to ever run it in a full ¼ mile and at an NHRA tech'd event. I upgraded my safety equipment to meet a 10.00 second ET since that is all my 6-point roll bar is good for. However, my first test pass I went 9.71 on just 12 psi of boost and a fairly easy launch. I ended up setting the boost controller to leave on 4 psi and hold it until 2 seconds and then ramp up to 14 psi. That way I wasn't in danger of spinning the tires yet could still run my 10.0x dial-in. It turned out to be a good bracket racing combination as I made it from 64 cars down to 5. In the quarter finals I forgot to open my CO2 bottle for the boost controller so I lost.
Over the weekend I made 15 ¼ mile passes all within 138 to 143 mph. The car had a couple issues to work through (shifter cable lost a bolt, cracked coolant tube fitting, IAC hanging the idle) but overall I was really happy with the performance and the handling at 140+ mph. The Martz chassis with rack-&-pinion steering and their recommended alignment made it very stable and each pass was dead straight. Seems to be a good blend of 44 year old parts and current technology.
