Are the front subframes on these years interchangable? 69-74? My 69 has some front frame damage so I am considering a frame swap.
James
James
I have one in my 71 also. You will also need to cut off the motor mount extension if you use your old style engine mounts. You could use the new style mounts and leave it on.I put a 74 subframe in my 72. Everything went in fine as far as engine etc. The only thing I had to change was to drill one new hole on each frame horn to mount the 72 bumper.
hi, can you post some pictures of the subframes you have? if you need really detailed info on the subframes, let me know i can help. if you have a strip car and not a conquers resto then you will be good to go...Cool I got a line on a 71 roller for $500, so it looks like I will have a donor soon.:yes::yes::yes:
James
