Are these all the same? Will a 73-74 dash fit a 72?
I would appreciate it, if you don't mind and I will post this in the best of Q & A for knowledge for others incase the ever want to know.I checked again and Taz is right there are some changes around the column, the pics should explain. I have both dashes and columns and don't mind swapping out to see if they either combo will work if you would like. Let me know my car is in the resto stage so it won't be alot of work. The 1971 has a bezel under the column the 1974 does not.
Pat
