My question revolves around a wiper switch for my 67 Nova. I ordered all new switches/bezels/nuts etc from CI. The replacement switch they sent has a shaft diameter of 0.500 and the 3 dowel tabs that keep the switch from rotating are much larger than the reliefs cut in the dash. The actual dash opening for the shaft is app 0.450 and I would suspect that the original shaft diameter should measure app 0.437 ( 7/16) . Has anyone else run into this problem and if so were you able to find the correct switch, and from which supplier.
Thanks for any enlightenment. :turn:
Paul
Paul
