1 - 3 of 3 Posts
both my vent windows had no handle on them, the am handles came with a spring washer and rubber o ring, which goes on first? Also does the pin go through the slot?
66 Nova SS
I put mine on with the rubber on first then the spring washer and yes the pin goes through the slot. Not sure if that is right but that's the way I did mine
i've tried 2-3 times to get my vent handle tight. i can't get the pin out or drive it any farther on ,but the window closes tight but the handle is loose. i went out an looked at the car an its rubber first the the washer. an the washer might be called a tension washer.
1 - 3 of 3 Posts
