So I was having issues with the horn honking when turning the wheel. I found some pinched wires in the column but I also found three small springs laying inside below the bearing retainer? Anyone know what these are and where that belong? I’m guessing they some how go around the three screws that hold everything together. I can’t find a column breakdown diagram anywhere. Thanks
It’s the original column, 4 speed car. These are the springs and the screws that I’m assuming there used on. These are the screws that go through the indicator switch, bearing housing and attach it all to the column. Could use a replacement screw! E73FE397-AD2F-43EC-B314-BEA331EEA840_1563762290135.jpeg 9C1FB9A8-F429-42EC-A7BE-A970D8D60BD1_1563762121785.jpg
Can someone maybe direct me where to go to find help? Clearly this is an issue that can’t be helped here. Thanks for trying though.
