Headlights not working
9sec67 said:
I have a 67 I got taillights, brakelights, ect, but no headlights. Where did I go wrong?
Also after you have tested for power by taking the headlights out testing with light @ plugs also check @ the headlight dimmer switch and the headlight switch. You can also check the headlights themsevles if you have a baterry charger, i have had were both headlights are burned out.
Good luck i feel your pain, Harley
same problem
My '67 had the same problem,,,,the plug on the back of the light switch under the dash was loose:D Hope you're as lucky:chev:
You got it thanks alot
