Greetings all you experts.
Here's my problem. Due to the extremely bad rust in the trunk I had to chop it out. I figured since I was doing it anyways I was going to replace the rear clip. I purchased the Chris Alston's canted type. I wanted back seats so I didn't go with the 4-Link..... I have to cut the belly pan now maybe 7-10" in front of the package tray support. While the car is just a shell I have wheeled supports on the front leaf spring holder but it needs to go.
I'm going to make a custom body cart for it but the question is has anybody ever used pinch welds on the rockers as support? I can figure out how to support it until I get the rear frame in and I don't need anymore damage.
My car is just a shell but I have it supported by the pinch welds. I made a 2
' square tube frame with scaffolding wheels on it and welded it front and rear to the edge of the pinch weld. It is rock solid and will be easily removed.
Pinch welds.
Did you have any problems with balancing? What is the height if you don't mind me asking? Height of the cart that is???
