Trying to install the VHX dash in my 66 and the assembly is hitting the light switch. Have any others that done this install seen this, if so what did you do? I don't know if I can rotate the switch and if I can if it will be enough.
Mine did too. I filed a little bit off the VHX to allow it to clear the switch. Probably other ways to resolve it, but that's how I did it.
I put VHX in my 66 at the some time I rewired with an AAW kit. I tried using the stock switch and had interference problem. I switched to AAW switch and it worked. If I recall right I did some very minor modification on the repop switch.
Another problem with that dash was compatibility with aftermarket air conditioning defroster ducts. I ended up making a custom one.
I love the dash but I took some work on other components to get it in.
Thanks, I did take the dremel to the dash to clearance it as well. Took more than I thought it would, but looks like it should all work.
