I am currently rebuilding a 327 engine and plan to go with a 700R instead of the th350 it currently has. Can I install that transmission from below once the engine is in or is that something that needs to go together first and drop in as one unit? I only ask because of how difficult it was removing the 350 top bell housing bolts from underneath. I ended up removing the intake for another reason and loosen the top bellhousing bolts from the top.
1967 Nova SS
It can be done. Trans jack helps considerably. But if you have the engine out, its much easier to install eng & trans as a unit.
i can't help on the install but i do have a 327 an a 700r4 in my 66. for a rear gear i run a 3.55 posi. sure is easy on the rpm's on the highway as 70 mph = 2200 rpm's.
this might be of interest to you........... Gearing Calculator | RPM and Tire Diameter to km/h - mph with Shift Tracer (blocklayer.com)
If you can bench press 100+ pounds and hold for an indefinite amount of time and repeat as necessary:mad:, install separately, otherwise ALWAYS install engine and trans as an assembly. Esp automatics!
Good luck!
The only way I'd try at my age is if it was on a lift. I have done several from the ground in my younger days but that is over.
