Vendor
It uses six studs with self-threading speed nuts. My guess is they added virgin studs that will get grooved when you install the speed nuts. Probably a positive sign in relation to their quality.
OH! And pictures of the dash pleas :)
The repop has more rounded edges and the original has sharper edges. The original is the darker. That was the color they copied from the underside of the pad that had not seen sun. The contours on the original are more pronounced and the repop are just rounded. I think the foam may be a little thicker on the original.
Vendor
Thanks for the pics! They both look good. The original does look thicker. The grain on the original also looks more pronounced, more detailed. What I can see of the studs on the redone one, I would say it is meant for a self-threading speed nut.
