1 - 20 of 20 Posts
Seeing if someone that happens to run the TCI protouring front clip can take a picture of the ground clearance they have in the front. Between the cross member and the ground. If they are running the 2in lowering spindles that would be exceptional as well. Im trying to see if there is enough room to notch the cross member for engine\pan clearance and add a strength brace below.
This picture is before i completed assembly. Car is lower now
Engine is a stroked LS. Installed a Holley 302-1, it hit the rack & pinion. Replaced it with a 302-2
I have the TCI PT front clip with the standard spindles. The ground clearance ie 4.875 to the R&P mounts and 5.875 to the crossmember. The R&P mounts are the lowest point.
TCI pro-touring front with 2 inch drop. Im running a 4.8 LS with a 4l80e and a turbo so all that adds some weight. That container under is 2.5 inches and there is another inch in between it from the lowest part of the power steering mount. So a total of 3.5 inches. My lowest part of the car is the 3 inch exhaust though, then the tranny followed by the front cross member. Im using the 1998- 02 fbody pan.
1967 2 Door
I have the older TCI IFS with 2” drop spindles, 225-45-17 tires and have 4 3/4”. Mine has a bigger cross member so the rack mounts are flush with the cross member. You need to have your lower A arms level, parallel to the ground, per TCI.
Are the 225’s on 7” wheels? I’m getting the TCI clip also.
What motor and pan are U usin ?
I am using a VW motor so the reason for the sectioning. (Yes I get lots of crap from my father for this choice)
407866
The oil pickup is right on the cross bar why the cut was made. I just see the picture and it seems WAY to low for it to not hit. I was not involved in this decision. I was informed after the work had been done. The engine is lower weight. Fully dressed it should be around 325lbs
Discussion Starter #11
Ill just have to wait till the engine is all in to see how low she goes then. Hopefully Ill be at the 3.5 is what the lowest was listed above is.
1963 Nova coupe, Phoenix Arizona
I am using a VW motor so the reason for the sectioning. (Yes I get lots of crap from my father for this choice) View attachment 407866
What VW motor ya gonna use out of curiosity?
Discussion Starter #14
A VR6. I have an older 12v mocked up currently but I might go with a newer 24v. I thought about trying to be fancy and using a W8 so I could appease more of the 8cyl die hards like my dad, but they are scarce and high cost of maintenance.
Hey that’s what hot roding is all about, do what you know and like 👍I don’t know anything about VW motors accept the flat 4’s I used to work on in the 70’s. So is it a 4-6 , turbo ?
Discussion Starter #16
It's a 15° V6 so it has one head even though it's a V6. It only takes up as much space as a 2.0 4 cyl. No modifications and adding some boost they are good for 6-700hp. Very robust out of the factory. Originally they were designed to be diesel generators. Have a pretty cool sounding burble if you Google "vw R32 exhaust".
Wheel specs will be covered in this tech thread.
I’ve fitted 235/45/17 and 18 inch wheels on a TCI MII clip. The wheels have 5.25” of backspace. Pictured with 18” wheels here.
That’s pretty cool never seen one before 👍
66 with TCI PT clip and stock spindle height. Tires are 255/30/20. Don't recall BS. Gen1 small block. Plenty of crossmember clearance.
1 - 20 of 20 Posts
