set it on the ground with all fluids etc... just a tiny bit too low (for street driving),... was able to check clearances on everything while there... though everything was very close, at this height, everything cleared... didnt leave much room for travel...
so, i remade the exhaust, doesnt look much different, but it is... was aggravating to do... got rid of the vband (was the closest part to the tire) and moved it a little further in toward the middle of the car... and as far away from the tire as i could get it, with this type of setup... with the wheel turned all the way to the left, it is close, but does have clearance... will add the heat protection back in this area too... hard for me to do much more, without the help of a lift (to hep me get into a more comfortable position)... may add a slip joint back in later... but i just wanted to do something to be able to run the engine (and try to avoid exiting out the fender/hood etc)...
