finishing up more wiring. continued to label things, as best i could, in case someone else ends up with this and for future reference... the trans psi (analog signal) will be left loose, until i can get the other holley display (that has more inputs for things...
the termx only has 4 inputs and 4 outputs...
for now, using the inputs for:
trans temp
oil temp (will be moved to the display and then will be a button for boost increase)
boost/psi (for boost solenoid)-from the map signal
flex fuel sensor
and the outputs for:
fans 1 and 2 (to msd relay)
Boost control solenoid
trans fan (to main fuse block/relay)
scavenge/intercooler pumps (to msd relay)
had to wire in a 5volt, with 10k resistor to the signal from the flex fuel sensor, so used this area to label the outputs
straight to the trans fan from fused/relay in trunk, controlled by the ecu
