I'm pulling the front of my 65 apart for a front clip install. I have always questioned wether or not the radiator was correct in it, I believe it is wrong. Is the radiator for a 65 supposed to bolt to the core support? Mine was sitting on these 2 saddles and had what looked like a homemade hold down. Thank you in advance!
The 1965 Nova Assembly Manual shows a shroud between the radiator and the core support for V8 engine. Mine has this shroud.
The radiator mounts to the shroud and the shroud mounts to the core support.
Rectangle Font Parallel Engineering Plan
