Wired up my car with a new wire harness ans all was fine & working. Took it to the body shop and when I got it back I have a problem. When you turn the ignition to power the hazard lights come on & with the ignition off when you step on the brake pedal the hazard lights flash. I did not wire up the hazard flasher power wire since I have not decided how & where to put the switch. So some where some thing is feeding power to that system. Does anyone have a color breakdown for the steering column wiring since I had it saved on my old computer that fried. Also any suggestions are more than welcome. I did check that it was not a grounding problem with the tail lights and all the fuses are working.
Thanks,
Miles
Thanks,
Miles
