I have searched the archives, but could not find any help regarding this question:
Will sedan, four door, or wagon A pillars interchange with a 1965 hardtop (no post A pillar)?
If not what is different- can others be made to fit?
I'm going to buy a 1965 Hardtop- it's pretty much a basket case. The worst part to me is that one of the A pillars is rusted through in two spots. The rust is not near the cowl (cowl looks very good) but pretty much in the middle of the pillar.
I think the best way to repair would be with a rust-free donor piece from out West. Hence the question of interchange. I believe a 62-65 hardtop (and possibly convertible) will interchange. I see that there are different windshield gaskets for a sedan- so I assume the pillar is different too? If so, can a sedan be made to fit?
Also, I ran across a vendor selling a reproduction A pillar for a 66. Unfortunately, I couldn't tell if this piece was the entire (structural) pillar or the trim piece. Could this piece be re-worked and made to fit a 65?
Thanks!
The only difference is the sedans and wagons are 1&1/2 INCH TALLER ROOF LINE AND A PILLARS. If you are planning on cutting a section out of the center there should be no problem with any 62-67 a-pillar to graft into the rusted area
Im pretty sure you can use any pillar to patch yours but if you want to replace the entire pillar, your going to want to use a hardtop one, because the height and angle are different.
Dale @ novasrus.com has good used pillars. Hes a member here on Steves; Blue66Deucex2
Thanks for the news, guys. If what Dueces2 says is true, I can buy a brand spakin' new pillar for a 67 from a vendor and use the middle to patch this rust bucket up. (Hopefully, blasting won't reveal any more extensive metal worm damage.)
This is good news for me. I don't mind welding on pre-made patch panels, even if they have to be seriously re-worked. It's the fabrication from scratch that I lack talent in. :(
