1 - 11 of 11 Posts
radiator
Check Nova Resource for sure if you can tell by the VIN and Cowl tag they will know. The six didn't use a radiator spacer and the V-8's did. All that is easy to change though. Using the cowl and VIN is the only way to be sure.
i've looked but i don't see where it tells u in the vin
the vin is 40447N22914
and the cowl tag
05D
Style 64 0447 NW
8206 Body
Trim 733
916 Paint
W2MPS3C5w
Gas Line
Acman,
I believe the V8 gas line ran in the outside passenger side fender well (behind the wheel) and entered the engine compartment near the battery tray. The 6 cylinder entered the engine compartment next to the brake line on the passenger side.
Mike
Yeah, what Mike is talking about, if you look closely under your battery tray if the car is a 6 cylinder you will see a plastic plug where the V-8 fuel line would have been ran through at the factory if it were a V-8 car. I know when I converted my 65 from 6 to 8, I ran my fuel line through there. Brett.
How 'bout just countin' the plug wires???:D
Z51JEFF said:
In the VIN a I6 was 437 a V8 was 447,I think.
In 1964, there was no way to tell from the VIN or cowl tag whether a Chevy II was a V/8 or six. 447 was a Super Sport and could be a V/8 or six. 437 was a Sport Coupe, again either a V/8 or six.
Bob
1 - 11 of 11 Posts
