My speedo is acting up the needle keeps getting stuck in different spots. Works sometimes and not at all. The odometer is working fine. Any ideas on rebuilding it or replacement guts
Cable is new. The needle is hanging up and sticking or not moving at all. The odometer still works
Is there grease in the new cable?
If you are able to spin the speedo housing assembly on the backside of the speedo cluster,does it spin freely?
If so, does the needle move in correlation on how fast you spin it?
How is the connection at the transmission?
Are the gears in your transmission in working condition?
Are there any sharp bends in the cable going to the transmission?
If the cable is in great condition, then the next logical step will be to replace the speedo. But, as you already know, those aren't cheap.
