No pics yet. But you can use your stock Powerglide/ manual trans crossmember to install a TH350. Just trim off the front lip edge of the crossmember to clear the TH350 pan.
Thats what I did in my 64.
The reason for the pic, is the one in the car is not right. Someone did some mods and even used a lag bolt on each side!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
yep that is exactly what I did too.:cool:
Thanks Kdee
Do you have a shot of how it is mounted to the subframe??
Here's a shot showing an aftermarket crossmember mounting to the frame stubs that all of the transmission crossmembers should bolt to. It's just two bolts that slide through the crossmember, across the frame stub, with a bolt holding it in place.
You can see the bolt holding it to the frame stub on the right hand side.
