· Premium Member
Trick here is to apply leverage straight up and minimize lateral forces. I used two stiff narrow scrapers with 45 degree angle on them and got one blade under the trim and the other on the opposite side and worked the trim off that way. Once you figure out where the pins are move your blades right next to the pins and apply leverage there. Mask with tape to protect the area around the trim. Good luck.
