This is the engine build thread for my Project "The Donation Wagon" with a low-mid budget but well assembled goal.
So to start off I've never built or owned an LS platform motor. Driven plenty at work and I have built plenty of SBC engines over the years so not shy to jump in on one. I am starting with a 6.0 LQ4 from (what I was told) a 2005 Chevy 2500HD It came with the matching 4L80E so the story from the seller seems likely. Supposed to have a little over 89K on it and I paid $500 so lots of room to work with. I have already snagged a 2005 GTO oil pan & intake with fuel rails and injectors. My original goal was around 400HP but I may be convinced to go a little higher as I would like to enjoy the car. Goal is fun and reliable. From what I have read I can get to 400HP with a cam, springs and tune fairly easily. I know if I go any bigger I will need a stall which is not out of the question. I came up with the 400HP+ based off of my 14 Dodge 5.7 which is about 400HP stock and it runs great in a truck so in a wagon it should be even better. I don't plan on tubbing the wagon so will be running 17x7 rims at this point in time (tire size still to be determined).
Question 1: I want to go cable Throttle body and I know the GTO intake opening is 91.8mm. What would be a good TB to run on it? I assume a 92mm will fit?
Question 2: What cam/springs/stall would you recommend for 400-450ish HP? Or other ways/mods to get to that goal zone?
Thanks to everyone who has advice and I hope the following build will be informative or at the very least entertaining!
Miles
Miles
