I am swapping this weekend. I am pulling the 6 for the v8. I read that is ideal to change the fly wheel to 153 tooth and high performance starter, is this true? Can i use the stock flywheel and starter from mid 80 350 in first gen?
You need a starter that will work with a bell housing and 153 tooth flywheel.
The orientation of the mounting holes on an automatic VS a manual starter is different. The manual starters have a staggered mounting bolt positioning as opposed to parallel bolt position (or vice-versa).
I'm not aware of a reason for not using a stock starter but there may be a good reason to use a "high performance" one (maybe smaller size--more clearance?)
First gen guys would know. Also, in case you didn't see it, there was just a good post on this forum about which bell housing you need for your first gen.
check bell housing
Thanks for the reply. How can i check the bell housing?
Also, I am going back with 700r4 out of 85 iroc. The trannie should fit using the old drive shaft and the short output shaft ?
The 700r4 is an automatic transmission which means you don't need a bell housing or a flywheel but just a flexplate. You would need a starter that works with small block chevy and auto trans. Don't know about driveshaft. 1st gen guys will know.
The starter and flex plate depends on how the block is drilled for the starter mounting. Pretty sure a 153 tooth fits with straight across holes in block. The 168 tooth uses the the diagonal or staggered bolt holes. I used a mini starter for the room near the exhaust. Also, I think the 194 six I had used the 153 tooth flexplate.
Good luck
Regarding the 153 tooth flywheel, I checked the casting numbers on mine when I bought it and found they used them in anything from a 194 to a Z28 302 with manual trans. :)
Good luck
Straight pattern on my 350's with 168 flexplate all the time.
400 small block uses the staggered with a 168 tooth flexplate and some have both bolt patterns. I always use the straight starter on my 400 builds and if they don't have the extra hole I drill and tap(when the bare block is on the stand) it then ream the 1st 1/4" with the next size bit like the factory did them.
