the chrome is NOT held in with plastic , they ARE held in with metal barrel nutsThey're held in with little plastic anchor sleeves similar to what you use in drywall, concrete, or tile.. Really tiny versions though..
You might be right on that.. I was looking at the trim bar on my 64 glove box door and might be remembering the 63 door differently then it really is.. My bad..!:turn:the chrome is NOT held in with plastic , they ARE held in with metal barrel nuts
the emblem has tabs on the back that get mushroomed down through the holes in the back of the glove box door ( you need to remove the hinge to gain access to the holes
I can see where I can get to the back of the emblem by removing the hinge, but getting to the back of the chrome piece looks virtually impossible. I’ll take a look tonight and hopefully have this resolved. Thank you gentsthe chrome is NOT held in with plastic , they ARE held in with metal barrel nuts
Mine had little metal ones that can be obtained from ChevyIIonly.They're held in with little plastic anchor sleeves similar to what you use in drywall, concrete, or tile.. Really tiny versions though..
SCHWABIE, I’m trying to install the chrome trim, not remove it.you don't need to get the back or the chrome trim , use a plastic trim tool to gently pry the trim off the glovebox
Thanks Powderski, I’ll check out their site. If you have a p/n it would be appreciated.Mine had little metal ones that can be obtained from ChevyIIonly.
I just saw this...this is what ya need 3/16" barrel nuts
click on the link
https://www.ebay.com/itm/NEW-2595-B...barrel+nut&_from=R40&rt=nc&_trksid=m570.l1313
