Will a s-10 rear-end fit in a 63 nova or are there any rear-ends that will fit easily.
thanks
Todd
thanks
Todd
You should be fine. I like the 7.5, it is a more efficient rear than most other rears. With a sixer I think that it makes a great rear. I have a s10 blazer frame in my back yard left over from another project I can measure and get you some dimension if you need. Oh yeah the S10 2wd are much narrower that the S10 4x4 rears, the 4x4 are about the same width but I'l have to remeasure to be sure.i have a 63 wagon with a stump pullin 194 but want to upgrade the wheels and tires.
thanks
todd
So are you saying that a rear end out of a 03 GMC S15 is 3 inches shorter than the 8.2 rear end out of a 64?S10 2WD's are 54" wheel mounting surface to wheel mounting surface. The Nova 8.2 out of my 64 was 57". I have one I bought out of a front wrecked 03 GMC S15. It has 3:42"s and a Gov Lock with drum brakes.
Scott
any one know if they made a 2 wheel drive or non Zr2 (wider track with ) s10 or gmc with a 8.6 . I know my 2002 gmc with the zr2 package has a 8.6 but like I said that has a wider track width than a standard s10. the 8.6 (basicly a 8.5 with 31 spline axel's in a real strong rear end. would be a great swap if they made the nerower version would be interesting to see how wide theZR2 one is also . mine also has rear disc break's Joel
Yes it is shorter by 1.5" on each side. The 2 wheel drive S truck rears are all 54". That is a good thing if you are trying to run bigger wheels and tires. Yes a Gov Lock is the G80 code and is a limited slip differential. Some are drums and some are disc. Try this for infoSo are you saying that a rear end out of a 03 GMC S15 is 3 inches shorter than the 8.2 rear end out of a 64?
and what's a Gov lock? is that GM's G80 posi?
just trying to figure all of this out
Mark
What is a 8.6? I have a rear end which came out from under a ZR2 which is a 8.5. It does have 31 spline axles. It measured 60" wheel mounting surface to wheel mounting surface if I remember right. It also has disc brakes as I think they all do. Mine was narrowed to 51". It has an Auburn posi in it and 3.73's. When I ordered a new ring and pinion it was for a 8.5.any one know if they made a 2 wheel drive or non Zr2 (wider track with ) s10 or gmc with a 8.6 . I know my 2002 gmc with the zr2 package has a 8.6 but like I said that has a wider track width than a standard s10. the 8.6 (basicly a 8.5 with 31 spline axel's in a real strong rear end. would be a great swap if they made the nerower version would be interesting to see how wide theZR2 one is also . mine also has rear disc break's Joel
an 8.6 and 8.5 are the same as far as I know except the 31 spline axel in the 8.6 so the spider gears would be diferent as well. I think carier and gears are the same as 8.5. I noticed the disc set up seamed to be what realy widend the thing , wonder if drum's off a 8.5 could go on one and help the width. thing? I know where a housing is may have to deal the guy out of it and see what I can come up with.What is a 8.6? I have a rear end which came out from under a ZR2 which is a 8.5. It does have 31 spline axles. It measured 60" wheel mounting surface to wheel mounting surface if I remember right. It also has disc brakes as I think they all do. Mine was narrowed to 51". It has an Auburn posi in it and 3.73's. When I ordered a new ring and pinion it was for a 8.5.
Scott
Get out the tape and seeanyone know if the mid 90's S10 rear ends are the same width as the mid 2000's? 54inches? sounds like most guys use the 90's. I found a 2004 for $400 complete with disk brakes and need to know if it will work under a mini tubbed 65.
Yes it is as long as you are not trying to add lots of HP to the car.i have a 92 s-10 collecting dust in my driveway, my 62 has a bone stock rear end,,,,is it worth me looking into swapping the s-10 rear into the nova,,,,
after all its free![]()
Did a little compairing on cariers the axel's on the 8.6 are way biger than a 8.5 carier the axel will not even fit though the carier to get even close to the spider gears. I do have a posi gov loc for a 8.6 with low miles 3 series gears go on it if any one is interested I am in north Idaho Joelan 8.6 and 8.5 are the same as far as I know except the 31 spline axel in the 8.6 so the spider gears would be diferent as well. I think carier and gears are the same as 8.5. I noticed the disc set up seamed to be what realy widend the thing , wonder if drum's off a 8.5 could go on one and help the width. thing? I know where a housing is may have to deal the guy out of it and see what I can come up with.
