1 - 3 of 3 Posts
I have a 63 ht and am considering installing a tci 4-link, 12 bolt and ez tub inserts. I want to get some more tire underneath the rear, possibly a 275. Anybody know what fitment i could stuff in the rear with the setup ive listed? I know the 12 bolt is wider but hoping to not have to shorten the housing or notch the frame. Any recommended setups for mostly street use? Lt1/4l60e. Thanks.
Sent from my DROID RAZR using AutoGuide.Com Free App
My 63 has a minitub and a 54in. wide rear.I've to 20x10s and 285-35s with 5in off set rims and they fit real close without major rubbing.
Thanks tuckin20s. Did you keep the stock mono setup or run a 4 link? Did you have to notch the frame? Im not worried about doing it, but know if you notch it you have to fabricate the 4 link to make up for the lost material. Any pics?
1 - 3 of 3 Posts
