Has anyone installed electric door poppers on a gen 1 and what brand or system did you us and like. Also any pics. Thanks
Banned
yeah, i did... i believe i used 75lb solenoids which i need stronger units. maybe the 100lb units would work longer. i installed the poppers below the door latches...
the kits on the market say 50lb solenoids are OK for a 2 door car.... the manufacturer/distributors said that they'd be too weak and wear out after a while and recommended i use 75lb units. pass side still works fine but the driver's door takes 2 clicks to open... i think the 100lb units would cure that...
make sure it's all wired through relays...
here are a couple images of my solenoids.
http://rides.webshots.com/album/289447714XwMQgf
Thanks for the info. I was searching and saw A.V.E make some kits too. Didnt know if it was a good kit.
