1 - 14 of 14 Posts
I have a problem with cracks in the forward rear spring mounts. I'm looking for suggestions on the best way to fix this. It has a mono spring. I have a 300 hp 350 with an automatic. It's an occasional driver but I'm woried I'll leave the differential on the road. Thanks in advance for any help.
if it's the spring perches that are cracking you should put u-bolts on instead of studs.
Miles
I'll try and get some pictures tomorrow, The cracks are in the bracket where the front eye of the spring bolts to the frame.
Has anyone done anything to eliminate the great big washer used on that front spring eye mount? Got pics?
Vendor
I made a stepped washer and welded it into the large hole when I installed my Caltracs.I will post pictures when I get home from work.
Vendor
I machined a piece of 3/16 plate with a step in it so it fit snug in the large hole in the spring pocket and welded it in as best possible.
I've seen that done on about 10 or so novas. Works good. just make sure the bushing gets a squezzed too. so it holds tight! Wish they had a bushing to go in there with a hardened sleave like the 68 up cars do. so the bushings don't wear as fast and keeps the leaf springs off the frame!
Discussion Starter #13
Thanks for all the info. I'll get it welded up and try and fabricate a washer too. I tried to load photos using the info in the FAQ section but no luck getting it to work. I'll see if I can figure out another way.
1 - 14 of 14 Posts
