If this is the same seller:There is a guy on ebay that has sold some refurbished original clocks that I may try.
http://www.parts123.com/parts123/yb...~S3NZ0RK8UI97882513358a~Z5Z5Z5~Z5Z5Z50000132AWho makes the 65 units? I debating between that and a Tach?
As far as one of the orgionals lasing, I have read there is a procedure for "winding" them you have to do everytime you disconect the battery to ensure that the spring does not become too tight.If this is the same seller:
http://www.ebay.com/itm/1963-Checy-...Parts_Accessories&hash=item27cdbe968d&vxp=mtr
I'm rather reluctant as this is just basically cleaned, lubricated, & running - however may still be short lived as 99% of the originals were. I think that the quartz movement/conversion is definately the way to go.
The site I linked in the post above has a great description of how these clocks work and why they all die. Even if you're going to get a quartz replacement, I highly recommend reading it just for the education.As far as one of the orgionals lasing, I have read there is a procedure for "winding" them you have to do everytime you disconect the battery to ensure that the spring does not become too tight.
I know it is in one of my old shop manuals from the 60s. if I remember corectly, you have to connect for a few seconds, let it wind down and then reconnect. a well placed swith could make the process much better.
great article, but I think the ones in our cars are a little diffrent, because I know they can be over wound. It has been 20 years since I took mine appart, but if memory serves corect, the winding arm works like a ratchet and if the battery is disconnected too many times in a short perioid, it over winds the spring and has to be manually sprung.The site I linked in the post above has a great description of how these clocks work and why they all die. Even if you're going to get a quartz replacement, I highly recommend reading it just for the education.
Funny I keep seeing this on CLThis thread got me curious, so I did a bit of digging and found this site this morning:
http://www.oldcarsweekly.com/restor...tting_the_ticktock_back_in_your_old_car_clock
I really, really want to take apart my clock now. And I wish I had about 10 broken clocks to mess around with.
