1 - 3 of 3 Posts
Ok I have a 63 vert
I thought it would have 4 lugs on it. Turns out there's 5 lugs all around
I measured from the inside of one stud to the inside of the furthest stud and got 4.75 inches. Again that's from center lug across to center lug.
First off I thought the 63 only came w 4 lugs!
Second since I have 5 lugs all the way around I'd like to find a disc brake upgrade kit for at least disc in the front that's as easy a bolt on kit can be with a booster pump as well.
Finally I'd like to figure out how big a tire I could fit on a 13" rim
Or how much bigger of a rim could I fit under this thing without changing rears or spindles.
Thanks for any input!!
1963 Chevy II wagon 400
Lucky you ! Looks like a 5-lug swap on it already, 14" rims would be better. Good luck.
So the 63 never had 5 lugs?
I have a set of 5 lug rims....but they didnt fit.
I guess cause maybe they're 15" rims.
So only 14" 5 lug rims will fit?
1 - 3 of 3 Posts
